Have a look at my attached .f3d file and give me a suggestion of the best way to trace the outside of this model all the way around. I'm struggling to do it the most efficient way although I can't do it but there's gotta be a simpler way. My way is to project which produces the faint pink line around the outside edges and then to manually add lines thus allow me to trace the whole model. There has got to be a simpler way to produce this model once I project the outside edges. I'm just having a hard time figuring it out. If you notice that once I project the outside of the imported model, and then I turn off all the bodies, thus leaving just the pink outside traced lines, how can I extrude from this? The way I would normally do it is to manually trace the pink lines, but there's gotta be a simple one click or two click solution that I'm missing. Any help would be greatly appreciated.
