Extrude using last value as default
EKMS
EKMS
Hello all.
Since yesterday's update, when extruding, instead of the default zero I get the last value entered as default.
For example, I extrude a face with 5mm and then, when I want to extrude another face it starts with 5mm as the default.
This is utterly annoying and it can cause performance issues (for example, if you want to extrude 1mm and it gets the last value with is, let's say, 100mm and it crosses a complex object).
This is on a Mac, no idea if it happens on windows as well.
Any idea?
RajkumarIlanchelian
@EKMS We are aware of this annoyance and we will be quickly addressing this. I will post here when we have an update.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
EKMS
Thank you!
RajkumarIlanchelian
We have deployed 2.0.10446 that should address this issue. Please update to the new version.
Autodesk Fusion
Join Fusion Insider
EKMS
I can confirm it's back to the usual zero default which means it's perfect again.
Thank you!
