Message 1 of 9
Hey There!
I'd like to use the Extrude command to extrude a sketch with the extend type "to object". However, i want to define an offset, so the resulting body is in the opposite direction of the object i am extruding to. The end result would be, that the body has the thickness specified minus the distance between the object and the sketch plane. For example, if the distance between the Sketch and the object is 50mm and i put in an offset value of 70, i would expect the end result to look like this:
with the body being 20mm thick.
when i try to do this, i get a Warnig:
But it does show me that the body should be 20mm thick:
am i doing something wrong or is this intended?
Best regards,
Markus
