Extrude Intersect - Question
docara
docara
Hello All,
Etsfrench had just done an amazing job of helping me with a problem. Watching their solution made me wonder if it is possible to use a body/component to form a Boolean subtraction between two entities but have that body/component remain after the operation - almost like an inverse intersect?
So a component automatically deletes the intersected portion of a 'body' that correspond to the shape of that component.
Matt
SaeedHamza
Just select the Keep Tool from the combine dialog box
Regards
Saeed Hamza
docara
Hi Saeed,
Thanks,I tried that based on your suggestion and its not quite what I was after.
If you think about it an inverse intersect would hollow out the intersection instead of creating an object which was intersected - very useful
Matt
SaeedHamza
I see what you mean now
Actually such feature isn't availabe at the moment, but there are some other workarounds that gives the exact same result you're looking for in few simple steps
Here is a screencast, i hope it helps
Regards
Saeed Hamza
docara
Bloody 'ell that was clever!!
