Extrude cut in bottom-up assemblies
aleksei_ovsienko
aleksei_ovsienko
Just a quick sanity check. Tell me if there's a better way of doing what I did.
I have a shell of 4 panels welded together that needs to be machined post welding.
So my approach was to go in the same order in CAD-  create parts, build the assembly, then "machine" it with Extrude/cut, put holes in, etc.
But apparently with external components - I can't. It won't let me extrude cut, says there are no target bodies to cut or intersect.
With internal components it does it no problem. But I don't want to break link with external components.
So I do "Derive" of the whole assembly, I derive bodies of 4 panels from the assembly into a new part. And lo and behold - I can now "machine" it with Extrude and it retains parametric compatibility with the original parts, meaning if I update the part and then update the assembly - it all propagates into derived design.
My only problem is that I now have an assembly whose only purpose is to serve as a source for Derive. Which is not ideal from data handling perspective and will be very confusing to everyone but myself to work with when I get hit by a car or deported to Russia.
Also I don't have the ability to work on a part from the assembly with Edit in place. Which sucks.
Is there a better way of doing what I did? Namely have a traditional bottom-up assembly that also lets you cut it without weird workarounds? And if not, is it something worth introducing?
TrippyLighting
That is the "correct" workflow. It is correct in the sense that it works, but clunky!
Yes, a better workflow for welded structures would be appreciated by many!
dlongB69QW
I have just ran head first into this really unfortunate Fusion limitation myself.
