Extrude at an angle
Extrude at an angle
whittakerdw
Extrude at an angle
whittakerdw
I am wondering if it is possible to extrude at an angle to be able to follow the poorly drawn red lines in the attached image. If not, I'm hoping there is another way that this can be done.
Thanks in advance.
whittakerdw
But I must keep the side profile the way it is. I should have added this to the original forum
etfrench
Sweep command should do what you want.
ETFrench
whittakerdw
Thank you. I can't believe I forgot about sweep.
melvinbrian3d
you can make a sketch of the line or offset the external line, then sketch the Profile size... and finally use the Sweep command using the profile and the Path that will be the inside offset.
MelvinBrian3D
