Extending two offset profiles to pipe body not possible?
DanielZhuk
DanielZhuk
Hi all,
I'm stumbling upon a problem in which I cannot extrude two profiles to one body at once.
A solution would be to extrude them one at a time. I'm just curious if it would be possible to do so in one go.
Attached a screen recording as well as the 3D file.
Kind regards,
Dan
TrippyLighting
If you use "split face" on the cylindrical inside face you can use the extrude to two sides and then pick each half cylinder as the object to be extruded to.
However, that adds another timeline feature, so you might as well use 2 extrudes.
g-andresen
This is because the two profiles are not extruded from the same surface elements.
günther
TrippyLighting
Actually, this can be done with a symmetric extrude and "All" for the Extend Type:
TheCADWhisperer
TrippyLighting
Sure!
g-andresen
I was referring to the "TO OBJECT" option shown in the screenshot.
günther
