Expressions use for dimensions
How to use expression while giving particular dimensions?
HughesTooling
What expression are you trying to enter? You should be able to enter it in the dimension or you could make a parameter. Help on parameters here.
Mark
Mark Hughes
Owner, Hughes Tooling
I am trying to assign one dimension to other i.e. want one dimension equal
to other.
HughesTooling
If the dimension is in the current sketch just click it and it will be assigned for you. If it's in a different sketch, edit the sketch and mouse over the dimension and you should see something like d2:10mm, d2 is the dimension's parameter you need.
Mark
Mark Hughes
