Exporting .STP with color?
Message 1 of 35
I have been using Fusion 360 and would like to export my models to my ECAD software, Altium..
There seems to be no options when doing a .stp export. I would like to the appearance colors of my parts so that when I import into my altium libraries, the parts won't all be grey...
My father uses solid works and when he sends me models in .stp, they keep the appearances and come in color.
I've read in the past that Altium doesn't keep colors with newer .step versions, but even when I re-import the .stp file back into fusion 360 the whole part comes out grey.
any solutions?
Replies (34)
Message 21 of 35
bronc3buster842001
Files are exporting with colors now.
The issue I was having with files scaling wrong on export was not in 360. Was another program I used since 360 was having issues at the time.
Message 22 of 35
bronc3buster842001
Well it all worked for a day or so. Now some files export with color and some dont.. Hope this can be fixed soon, as I want to share a bunch of my files but not without the colors
Message 23 of 35
Phil.E
When you export these, the software that opens the exported models also needs to be able to show the colors. What program is opening your exports and not showing colors?
Can you post an example of a model that exports with color, and one that does not? It's also quite possible you are using Fusion specific materials/appearances that do not translate with STEP, in which case you would want to narrow your use of appearance materials to those that export well in STEP.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 24 of 35
bronc3buster842001
((It's also quite possible you are using Fusion specific materials/appearances that do not translate with STEP, in which case you would want to narrow your use of appearance materials to those that export well in STEP))
The models that dont have colors all worked before one of the last 2 updates.. I use Diptrace PCB designer, Freecad,Cad Exchanger,and have re uploaded them back to Fusion 360 as step..
Message 25 of 35
bronc3buster842001
Uploaded both the step and 360 file
Message 26 of 35
Phil.E
For some reason step export does not honor colors applied at the child subcomponent level. This means a subcomponent of a subcomponent.
The simple two pin connector is a root body with some face overrides for the gold.
To make the other file work, I moved all the bodies into the top level of the subcomponent.
The round trip step file looks like this when opened again in Fusion.
I'll ask why this is. It may be a limitation to step itself, based on the simple structural change made to defeat it. In any case, I'll try to get a better answer and perhaps log an improvement request to honor step colors at all levels of assembly.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 27 of 35
bronc3buster842001
Seems odd that it worked fine before one of the last 2 updates..
Message 28 of 35
bronc3buster842001
This file exported fine the other day, and use to work before then..
Message 29 of 35
Phil.E
I'm not sure it did, but if so this would be a higher priority. But only some testing on old builds will tell. Thanks for letting us know.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 30 of 35
bronc3buster842001
I think i have file that I exported with the older builds. Ill have to dig around and see..
Message 31 of 35
Phil.E
@bronc3buster842001
This has been reported to me as fixed for the January 18 update. Please give it a try after that and let us know if it works to your satisfaction.
(internal reference UP-32565)
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 32 of 35
bronc3buster842001
Was the update released yet. Check my software couple times and it never updated
Message 33 of 35
brianrepp
Hi @bronc3buster842001 - we found an issue in the update yesterday, and delayed releasing it until today (~6pm PST).
Message 34 of 35
bronc3buster842001
Software updated, and it works.. First file I exported with all its colors.
So was it a bug or something that got screwed up in an update somewhere along the line
Message 35 of 35
Phil.E
Glad to see it is working for you. Thanks for updating the thread.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
