Exporting sketch/flat pattern line types to DXF for laser engrave/cut
jcbyrd24
jcbyrd24
I'm having what seems to be somewhat of a common issue and I cannot find a work around despite reading many existing threads. I'm trying to provide files to a laser cutter with a distinguished line type for etch/engrave vs cut. Specifically in this case the center bend line, but in the future it may apply to text, etc.
When exporting as a flat pattern I get all bend lines (inc. extents) that do show up as a different line type ( in say DWG Trueview) but I don't want the extents. They are exported even if not visible in the flat pattern.
If I make a sketch and export that I can easily enough get rid of all the bend lines, but can't seem to keep the center as a different line type (using construction line in sketch exports to a figure line).
My last attempt was to use Fusion itself to simply edit the DXF from the flat pattern export, but I cannot save that DXF back to my computer, only to the cloud?
Can someone recommend a work around or a simple DXF editor. I downloaded Autodesk Design Review this morning and couldn't even get it to recognize a Fusion DXF export.
jhackney1972
Maybe this video will give you a workaround method you can use.  The Bend Lines, if chosen, are exported as solid continuous lines.
John Hackney, Retired
jhackney1972
You did not mention your Fusion 360 License type but with a Subscription license you can create a 2D Drawing, suppress the bend extents lines, title block and border and export to DXF from there.
jcbyrd24
Thanks for the help. I do have a subscription license so both of these options are available to me but neither really meet the need. I downloaded a free 2D program that allows me to quickly delete the bend extents layer and change the color of the bend layer and check scaling.
