Export to STL changes size 250125
pittsallen
pittsallen
Hello Fusion forum,
Have completed seven pointed star
SPS_250219.f3d
attached herewith.
In preparation for printing the model
is saved as an STL file for input at
the slicer.
When the F3D file is saved as an STL
file the STL model is about ten times
the size of the f3D file.
The export has been tried two ways:
1. With the model open in Fusion ver.
2.0.20981, the File icon in the banner at the
top is clicked and the 'Export'
option is chosen. In the Export
dialogue box the file type is chosen
as STL and the Export button clicked.
2.
 the Component is right clicked
and Save as Mesh is chosen. In the
Save as Mesh dialogue box:
Preparation Type: Export
Object: 1 Selected
Format; STL (Binary)
Unit Type millimeters
are selected and OK clicked.
This results in a Save Aa
dialogue box which allows
for a filename to be chosen
and the location for the file.
 Both methods result in a model that
is many times larger than the original.
How can the f3d file be saved as an STL
file without changing the size?
Thanks.
Allen Pitts
jhackney1972
You want to Save as Mesh, from the Browser, using the Body of the Component.  In the video I show this and also import the STL to show it is the same size. STL is attached.
(view in My Videos)
John Hackney, Retired
HughesTooling
EDIT. In the future can you please just paste the pictures into your message. Attached images can not be viewed with the text or 2 at a time.
@pittsallen  My guess is you used Open to open the STL and Fusion will assume the file is in CM, Fusion does this for all unitless files.
If you start a new design and use Insert Mesh from the insert menu Fusion will insert the STL using the document's current units or you can override if you need to.
Here I inserted the mesh back into your file and you can see the original and mesh are the same.
Mark Hughes
Owner, Hughes Tooling
pittsallen
Hello Mr. Hughes,
Not sure I understand this:
...Fusion will assume the file is in CM, Fusion does this for all unless files.
So I think what we are saying is that in Fusion
- Go to the top banner and choose New Design
- Go to the Mesh tab
- Click Create
- Choose 'Insert' Mesh'
- At the 'Insert'' dialogue box navigate
     to the STL file exported from the f3d file with 'Saveas Meah'
- This results in a dialogue box titled 'Insert Mesh' with
   Unit type: Millimeter
   Flip Up Direction
   Position: center
    Move to ground
   Numerical inputs reset
Click OK
This results in a model which is 234,786 mm, image copied herewith below.
So I missed a step or included a step that should be omitted.
Where did I go wrong?
Thanks.
Allen Pitts
HughesTooling
To me it looks like 234.786mm which I think is correct?
A quicker import is just from the Insert menu, no need to go to the mesh workspace.
Mark Hughes
HughesTooling
@pittsallen wrote:
Hello Mr. Hughes,
Sorry, spelling mistake should have been Unitless not unless.
When you Open\Import files Fusion will import Unitless files as CM so an STL saved in mm will end up open 10x too big.
Mark Hughes
