export to DWG
export to DWG
export to DWG
I would like to export files to DWG format (3D version). Is this possible with Fusion 360? I googled briefly something but the answers i found didnt match the functionality i see on my screen for some reason. Me being a Fusion 360 Noob could be a cause offcourse.
So can anybody help me out how to export to DWG with Fusion 360?
Thank you very much!
HughesTooling
You can only export to a 3d DWG using the online dashboard, link below.
https://myhub.autodesk360.com/g/all_projects/active
Navigate to the design and there will be a download option top right of your screen.
Mark Hughes
Owner, Hughes Tooling
henrycasson
Also, if you have Draftsight( free version is pretty good), you could open up a saved DXF, and resave as a DWG). If you want a DWG, presumably you already have a program that will open a DWG, and most likely it will also open a DXF and allow you to resave.
Henry.
retired Doc.. should have been an engineer.
henrycasson
Skipped over the 3D requrement, so my answer probably does not apply.
Henry.
No problem thanks for responding anyway!
