Export STLs at high resolution
tedj1
tedj1
Hi.  I'm trying to export from Fusion 360 with high resolution, because I'm having trouble with axles and holes having such low angular resolution as to grind against each other instead of rolling smoothly with 3D printed parts.  Someone showed be that there is a way to export STLs and change the resolution for components and bodies, but I'm exporting assemblies of parts and would like to maintain their spatial relationship to each other.  Save As STL won't do that.  Is there a way to change the Export resolution instead?  Thanks.
HughesTooling
Just did a test and if you only have the components visible you want to export then right click the top component and select Save As STL only the visible components export.
Mark
Mark Hughes
Owner, Hughes Tooling
tedj1
Da man wit da plan.  Absolutely right, HT.  Problem solved.  Thanks.
