Export spline as txt or xls file with x y z coordinates
Message 1 of 13
I have a spline or series of splines that I would like to export as a series of coordinates in x y z. Is there a way to do this? Can I control the step size (ds) between coordinate points?
Replies (12)
Message 2 of 13
jameschowe
Hi Spencer
I have never personally done this myself, however, there is a tutorial on the knowledge network, for importing XYZ data from excel into fusion which looks like the airfoil addin from the store.
I am not sure if this helps
https://knowledge.autodesk.com/support/fusion-360/getting-started/caas/screencast/Main/Details/c1d0d...
James
Message 3 of 13
Hi Spencer, I am having the same question you have. I know that Solidworks allows you to do so through its API, but not sure about Fusion 360. Just wonder if you have found a way to export the spline into XYZ coordinates in Fusion360?
Thanks.
Message 4 of 13
No, I have not figured it out yet. I tried using a program called Dxf2xyz,
but I kept getting errors when trying to convert the files.
Message 5 of 13
TrippyLighting
In general, this makes very little sense.
In order to understand what, you need to understand that the fit-point splines in Fusion 360 are 5-degree multi span splines.
Even if you export them into a text file, the chance that another software uses exactly Fusion 360's implementation and representation of splines the data you have is pretty useless.
Message 6 of 13
Hi there, I am trying to achieve the same goal as Spencer. I have a spline in Fusion 360 (that I created by tracing an image I imported as a canvas) and would like to export the xyz coordinates, and ideally be able to choose the distance between points.
This should be a relatively simple task... do you have any suggestions as to how I can go about this?
Message 7 of 13
TrippyLighting
What would you do with these points?
Message 8 of 13
The end goal is to use them for a NEURON model, so being able to export them to any MATLAB-readable file (even an Excel file) should do.
Message 9 of 13
TrippyLighting
And what is a NEURON model?
Message 10 of 13
A Python-based software for modeling neurons.
I just need a list of xyz coordinates in order.
Message 11 of 13
TrippyLighting
So the next question is: How would a list of fit-spline control points for a 5-degree multi-plan spline help you model that?
It is very unlikely that ant other software is going to implement fit-point splines the same way Fusion 360 does.
You have a much better chance with control point splines (CV splines).
Anyway, there is an API section for this forum where you might have better luck with such questions.
Message 12 of 13
OceanHydroAU
This is the snippet to get the control points of splines:
foil=[]
for i in spline.entity.geometry.controlPoints.iterator():
    foil.append([ i.x, i.y, i.z ])
You could theoretically do that as a one-liner in the "command window" from fusion360 itself if you can figure out how to select and reference the spline you want.
I don't know what algorithm Fusion360 uses for fit-point-splines.
Control-point-splines (and probably higher degree too) are standard cubic b-splines, and match pixel-for-pixel.  In perl, I used Math::Jspline.  I translated that to python in my Airfoil Tools add-in.
My addin exports splines to files (.dat and .csv) - it's built for airfoils, but if you turn off the normalization etc it should work for any spline: https://apps.autodesk.com/FUSION/en/List/Search?isAppSearch=True&searchboxstore=FUSION&facet=&collec...
If your splines *are* airfoils, you can export and re-import - the latter gives you options to re-spline and select the number of control points you want etc.  (but if you're just wanting the best airfoil for your specific use case, use what's already built-in - they outperform most other foils be a wide margin).
Message 13 of 13
jfsandvl
Community Visitor
Community Visitor
Spencer. Thank you very much. It Airfoiltools worked perfectly. my best regards...
