Export obj?
Export obj?
Message 1 of 8
Export obj?
I wanted to try exporting to obj but I did not record any file!
thanks
Fabio
Replies (7)
Message 2 of 8
keqingsong
thanks
Fabio
Hey Fabio, do you have a design you'd like to export to OBJ?
Here's a video of how to do it in this new version of Fusion 360, let me know if this helps.
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Message 3 of 8
Ok for the video ...
I was hoping to save an entire model using the export by the "hamburger" where I saw that there is a possibility, but it does not save anything!
thanks
Fabio
Message 4 of 8
keqingsong
Are you trying to export one of those mesh bodies as OBJ or are you trying to export all your mesh bodies as one OBJ file?
Keqing Song
Message 5 of 8
all together
Message 6 of 8
deyop
Currently the OBJ output only supports exporting an individual mesh.  The OBJ option in the Export menu is a defect and should not display OBJ as a format type.  Sorry for the inconvenience.  We will expect to provide multiple mesh exports in a future release.
Message 7 of 8
ok, not a problem. I explored the news and I was curious.
I teach a course in design and I am using Fusion for educational purposes.
Ciao
Fabio
Message 8 of 8
   The feature to transfrom to mesh (OBJ file) is good for a single object, then how can we use this method to transform a whole model (typically assembly from SolidWorks with 10+ parts) to a new OBJ model containing all the parts ? Is this feature existing now ? Any idea of a workaround (maybe using several tools in a workflow) ?
