export joints
export joints
Message 1 of 8
export joints
Hi is there any way I can export a complete setup with joints to some file I can then read in my own application?
Replies (7)
Message 2 of 8
Beyondforce
What application?
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 8
jeff_strater
The answer, unfortunately, is no.  None of the standard formats, such as IGES or STEP support any sort of joint definition.  The only application that understands Fusion's joint model is Fusion itself.
Jeff
Jeff Strater
Engineering Director
Message 4 of 8
Okay thanks, is there no other way like through the api or something?
Message 5 of 8
hclmed
Since USD itself supports joint definition, would it be possible to convey the relationship set in Fusion 360 in a USD file?
Message 6 of 8
hclmed
It seems that the joint types in Fusion and USD used for Omnivision/Create pretty much align. There's also a Fusion 360 "Connector" in development by Eric Bowman at Nvidia, previewed here: https://www.youtube.com/watch?v=EePFBWxSpUQ.
The UsdPhysicsJoint Class, https://graphics.pixar.com/usd/dev/api/class_usd_physics_joint.html, seems to encompass the joint types defined in Fusion 360. Is there any reason they can't be defined in an export?
Message 7 of 8
jhackney1972
Removed.
John Hackney, Retired
Message 8 of 8
hclmed
Yes, functional would be the goal. I don't know how Fusion stores its joint definitions, but the open source USD API supports all the required parameters for a functional joint. There should be some way to map Fusion's internal definition for each joint, to that API.
