04:03 AM
I'm working with sheet metal for the first time. When I try to export my flat pattern to DXF, it gives an unknown error.
I read in the help that flat patterns may have issues exporting if you've modified the sheet metal with extruding. I have done this — it's the only way I knew of to cut holes in it!
I've tried suppressing my screw chamfers in case that was causing issues, but that didn't help.
Anyone any ideas what I can do?
(File attached. I'm trying to export the components "Top (SM)" and "Bottom (SM)".)
