Export as Inventor File
I would like to turn my Fusion Model into an Inventor Model so that I can import it into Simulation Mechanical and have it keep material properties and the like. I cannot directly export an Inventor file from Fusion, but if I "share public link" and follow said link, I get an online viewer of the model, from which I can download an Inventor file. It would be more convenient to just export an Inventor file.
Alternatively, it would be nice to get some better integration between Fusion 360 and Simulation Mechanical. The built-in static FEA and simulation are nice, but I usually want multibody dynamics, like Sim Mechanical or at least like Solidworks' motion analysis.
TMC.Engineering
I think you can export from A360. I am not sure if everything comes over but you can give it a try.Screenshot (3).jpg
Timm
Engineer, Maker
System: Aorus X3 Plus V3, Windows 10
Plymouth Michigan, USA
Owner TMC Engineering
schneik-adsk
The solution above is the best way to get an Inventor Assembly.
Kevin Schneider
schneik-adsk
Kevin Schneider
