Export all repertory in step
I'm done with one of my project and I would like to export all the repertory in a step format. When I try to download my repertory, it makes me a .zip with nothing inside.
Is it possible to export or download several files (at the same time) in a step format or should I download all files one by one?
Thanks a lot,
(sorry about my english)
lucasliraAU
Hello
Fusion 360 enables you to download in STEP format. for any type of project be it a single part or a single design composed of several components in its structure.
If you are not able to export your work in STEP format. within the interface I recommend you use the A360 so you can download your file in all formats provided by Fusion 360.
I hope this information can help you in your work!
Greetings from São Paulo - Brazil.
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
