Experiencing problems with creating threads
Message 1 of 14
How do I build the outside thread on this oiler cup? It keeps wanting to thread the ID.
Thanks.
Replies (13)
Message 2 of 14
Beyondforce
You are right, something is wrong! Maybe @jeff_strater will be able to help.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 14
HughesTooling
It looks like the thread tool will not let you selected a tapered cylinder. Change the angle below to 90° and it works. If you need a tapered thread you could use coil and construct it.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 14
Beyondforce
Mark, that was a good catch 🙂
Ben Korez
| YouTube
Message 5 of 14
can you illustrate how to go back and change this dimension to 90 degrees.  Im doing something else wrong.  once I change it, the time line won't allow me to change where I am at in the drawing.
Message 6 of 14
TheCADWhisperer
Use the Origin geometry whenever possible.
You wouldn't walk out to the shop floor and start machining this part from any location in space.
First thing you do is set up your origin.
Message 7 of 14
Beyondforce
Here you go:
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
| YouTube
Message 8 of 14
TheCADWhisperer
You can right click to get to Diameter Dimension.
Message 9 of 14
HughesTooling
I guess you've not found the help, it is quite well hidden unfortunately!
How to edit sketch
Mark
Mark Hughes
Message 10 of 14
TheCADWhisperer
Use Geometry Constraints in preference over angle 90° dimensions.
Message 11 of 14
You guys are so awesome.
I appreciate your patients with my dumb questions.
Herschell
Message 12 of 14
HughesTooling
@TheCADWhisperer How are you getting the diameter option, if I right click a dimension I don't have that option.
Right click edit.
Right click while applying dimension
Mark
Mark Hughes
Message 13 of 14
Beyondforce
There are no dumb questions only dumb answers 😉
Ben Korez
| YouTube
Message 14 of 14
HughesTooling
@TheCADWhisperer OK figured it out you don't pick the line you're dimensioning you pick the 2 lines it's joined to.
Mark
Edit Or a line and a point.
Mark Hughes
