Error: The rails do not intersect all profiles
Message 1 of 23
I am new to the whole 3D CAD community.
I am trying to create a shoe last in Fusion 360.  Currently I am trying to model the back/heel part using Loft and Rails.  The profiles select but when adding the rails the error message displays "2 Error(s): The rails do not intersect all profiles"
I watched various screencasts in this forum on loft and rails, tried to apply that to what I am doing but with no success.  I used the 'Intersect' command to intersect the two profiles to the three splines I am using as rails .  (Each spline point snapped to the purple dots on the top and bottom profile)
Are you able to see something that I might be doing wrong in the attached screencast?
Is there something about the bottom profile shape that is unable to use the rails?
Replies (22)
Message 21 of 23
cekuhnen
@davebYYPCU @bradanlane @Anonymous
since I work  with fusion the sketch engine suffers from such problems
this dates back quite s long time
it seems however we - users that use those functions in Fusion are in
the minority and thus do not get the attention for development to fix
thise sketch engine issues
I would suggest to make your concern more known by the fusion team so
that they see that not few people only need those common must have foundational
sketch engine tools to work vs what AD thinks engineers only work with.
I understand their reasoning but the current course prevents everybody that needs
to design something that uses more complex sketch tools form using fusion
in a successful way which is pretty sad considering how amazing the rest of Fusion is.
in my furniture design class Fusion is amazing - in my industrial design course fusion is
to be honest sufficient for prototypes but it cannot compete with anything else on
the market.
and fixing few areas would enable it actually to do so like with improving loft and the sketch engine.
it is only a bottleneck issue.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 22 of 23
lichtzeichenanlage
@Anonymous: Wow - your are really using a lot profiles with a lot points in the splines.
Message 23 of 23
farisafana
Community Visitor
Community Visitor
This worked for me! Thank you for the solution.
