Error Rendering Turntable 36 Frames
rivendellnaturals
Observer Observer
rivendellnaturals
Observer
Observer
Hey, I've been trying every way to render the 36 frame version of the turntable. I get the same error every time moments before it's complete. Just that it can't render the file.
I've tried low res versions, high res versions and standard or final setting with no success.
The weird part is every time I use the 6 frame setting it renders out perfectly. It's only 36 frame versions that screw up.
I have a few screenshots, but I'd like to share privately if you need them. Thanks.
Mike.Grau
Hi @rivendellnaturals,
Thank you for raising our attention to that.
Could you may share the screenshots and your file with us.
You can directly send it to my email address mike.grau@autodesk.com
rivendellnaturals
Observer
Observer
I sent 3 screenshots yesterday to the address mentioned. I did not receive a reply or confirmation you got them. Thanks.
Mike.Grau
Thank you for sharing the screenshots.
I have received them and review them. I do already have a hint what could cause the issue.
Could you may share your file with me via public link. You can send it to mike.grau@autodesk.com
I have the feeling it might depend on the named views.
I´m looking forward to check your file.
Mike.Grau
Thanks again for sharing the public link to your design.
I have tried to download the file but the download link has not been valid anymore.
Could you may share it again with the password to mike.grau@autodesk.com
Thank you,
