I have a design with multiple components and all components except one provide a proper mass when i check properties of the component. The particular one which doesnt provide a correct mass gives an error of 1.147E + 04G.
I then created a test component to try and find out why its not showing correct mass and i started off with a smaller component ( which worked ) so i would be led to assume that its a decimal issue perhaps . The software is showing mass of my components in Grams although my user preferences are set to KG ....
Is there a volume limit to calculate mass that im perhaps missing? I did read about hidden components ( hence the plain test component ) so not sure what else i could be doing wrong?
