Error importing F360 generated DXF into Altium
l_wcrenshaw
Message 1 of 21
l_wcrenshaw
I created a land pattern for a surface mount PCB component that I'm trying to import into Altium Designer.  Altium doesn't like the F360 generated DXF file.  I get the following import error:
"ERROR : The file could not be processed - Can't get current mlstyle"
Is there any insight you could shed on this?  I can import DXF files generated from other CAD systems.  Thanks.
Replies (20)
Message 2 of 21
ADSKDJW4
Hello lwcrenshaw,
I am not sure if this is a known issue but I am looking into it. Does Altium have other import options other than DXF? I will see if there are other options here and post back.
Don Warner
Message 3 of 21
l_wcrenshaw
For land patterns, I can DXF or DWG. Both fail, but with different errors. What intrigued me about the DXF failed import was that Altium listed what was missing from the DXF file. I have no problems importing DXF or DWG files generated from SolidWorks 2104. Thanks.
Lewis W. Crenshaw, IDSA, PMP
Infinite Mind Designs
Message 4 of 21
ADSKDJW4
Hello Lewis,
Thank you for the reply and added information here. I am still checking with staff on this to see if it is a known issue. I may need to get the development team involved on this and will post back. Thank you for posting this and bringing it to our attention. I will keep you updated on this.
Best regards,
Don Warner
Message 5 of 21
innovatenate
Autodesk Support
Autodesk Support
Lewis,
Could you clarify the exact build of Altium Designer that you're using? Is it the latest version?
I note that Altium Designer 14.0 support DWG versions  2013:
http://techdocs.altium.com/display/ADOH/Enhancements+to+AutoCAD+Import-Export
I'll have to check which DWG is which version from Fusion 360. Perhaps the versions are incompatible...
Are you exporting a DWG from the command in the Drawing Environment or are you exporting a DWG from the Project Dashboard?
Also, you mentioned that "Altium listed what was missing from the DXF file." Could you share a screenshot of the error message or note what the message is saying here?
Thanks in advance for the clarification!
Cheers,
Nathan Chandler
Principal Specialist
Message 6 of 21
l_wcrenshaw
Sorry for the delayed response; I've been on travel.  I have not been a good customer w/ re. to maintaining a subscription (those cursed maintenance fees!!!), so I'm running AD10 (2012).
Re. the DWG error, I am exporting the DWG from the drawing environment.
Re. DXF, I get the following message when I try to import a dxf:
My preference is to import a DXF b/c it's cleaner--no drawing template needs to be deleted.
Thanks for your help.
Message 7 of 21
bob_holland
Autodesk Support
Autodesk Support
@l_wcrenshaw,
Is it possible for you to post a sample file that fails so that we can take a look at it.
Thank you.
Bob Holland
Autodesk Product Support
Message 8 of 21
l_wcrenshaw
Sure.  Here's the file that failed.
Message 9 of 21
bob_holland
Autodesk Support
Autodesk Support
@l_wcrenshaw,
Can you tell me what kind of error message you are receiving?
I was able to upload and open the DXF file in Fusion 360 and it looks just like it does in AutoCAD.
Thank you.
Bob Holland
Message 10 of 21
l_wcrenshaw
Message 11 of 21
bob_holland
Autodesk Support
Autodesk Support
@l_wcrenshaw,
Can you please try again.
Maybe there was a hiccup in the upload translator.
Thank you.
Bob Holland
Message 12 of 21
l_wcrenshaw
Zipped it this time...
Message 13 of 21
bob_holland
Autodesk Support
Autodesk Support
@l_wcrenshaw,
I was able to upload that one into Fusion also.
Have you been successful in uploading other DXF files?
Thank you.
Bob Holland
Message 14 of 21
bob_holland
Autodesk Support
Autodesk Support
@l_wcrenshaw,
I have been successful in uploading you file from both a Mac and PC.
Can you please provide me with your Diagnostic Log Files:
Thank you.
Bob Holland
Message 15 of 21
l_wcrenshaw
My issue is taking an F360 generated DXF and not being able to import it into Altium. I think you're looking at it the other way around 🙂
Message 16 of 21
bob_holland
Autodesk Support
Autodesk Support
@l_wcrenshaw,
I am wondering if your version or Altium does not support a 2013 DXF file.
I have attached a 2010 and 2013 DXF file from AutoCAD for you to test.
Please let me know of your test results.
Thank you.
Bob Holland
Message 17 of 21
bob_holland
Autodesk Support
Autodesk Support
This time with the 2013 dxf file.
Bob Holland
Message 18 of 21
l_wcrenshaw
Interesting.  Both the 2010 and 2013 files import just fine.
Message 19 of 21
bob_holland
Autodesk Support
Autodesk Support
@l_wcrenshaw,
All of the other applications I have test seem to be fine with this DXF file.
Here is a free viewer also.
https://360.autodesk.com/Viewer
Have you consulted with Altium to see what they say about their software giving the error:
Thank you.
Bob Holland
Message 20 of 21
l_wcrenshaw
Since I let my subscription expire, I don't think that I'll get much help.  Regardless, I appreciate all of your help!
