Error Hub Suspended
Error Hub Suspended
CAMendoza3D
Error Hub Suspended
CAMendoza3D
When trying to make a new project inside Fusion 360 it tells me "Operation failed" on the project itself (then deletes the folder automatically) and at the very top (above your user name) it says:
ERROR_HUB_SUSPENDED
1. I'm on a windows 10
2. Logging out and back in did not solve the problem.
4. I will contact my admin and have him confirm that I have the necessary permissions/rights on the hub in question. (Yes I believe it is a TeamHub).
5. I have the folder Diagnostic Log Files
Thank you for any help in advance.
pawel.potyrala
Hi @CAMendoza3D,
Thanks for posting. The suspended state was lifted and the Hub should be available already. Could you check and confirm?
Thanks in advance,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
CAMendoza3D
muchísimas gracias pawel , se ha resuelto el problema
