Equal Radius For Sketch Offset Corners
I'm trying to sketch a series of rectangles with filleted corners _with equal radii_. Unfortunately, when you offset, the radii changes and when you try to dimension the offset rectangle corners, Fusion complains that it would be over-constrained.
Any ideas of how to create concentric filleted rectangles with equal radius angles?
jeff_strater
The reason why offset produces different radii for the filleted corners is because that is necessary to maintain the "constant distance" necessary for a true offset.  So, if you really want an offset that has the same radii as the source, I would just do that by constructing it.  Here is a screencast:
Jeff Strater
Engineering Director
Thanks! Just what I needed. It would be great to have this as an option during offset, but I understand it might be an edge case. For reference, I was creating an end-cap that would slip over the end of an extruded rectangular shell, and needed to make a piece that would fit the inside and the outside of the shell, hence multiple offsets. Thanks!
