Equal constraint.
Equal constraint.
107merc
Equal constraint.
107merc
After opening "sketch" I make a set of parallel, vertical lines, 1, 40mm long and 1, 20mm long
starting at the same line but slightly apart.
I then select the equal constraint, select the shorter line then the longer and the longer
matches the shorter. As it should.
I make another set of parallel lines, select the longer then the shorter then the Equal constraint
and while the shorter line does becomes longer it does so below the starting
point of both lines instead of going up to match the longer line.
Any info appreciated.
jhackney1972
I will make a guess, your shorter line is not "coincident" with the base line.  As you can see the test you describe works perfectly and the short line matches the long line's length.  Attach your model and we will see.
John Hackney, Retired
Drewpan
I would strongly recommend that you do the embedded tutorials in the Fusion Documentation and also some of the
Self-Paced Learning to help you to learn fusion faster and better. They can be found here:
It is also much easier for the forum to help you if you attach your file AND a screenshot of what you want to achieve
and what the problem is. You can create a file to export like this:
Time spent on the tutorials and self paced learning will not be wasted.
As @jhackney1972 has suggested, this is probably a case of the second set of lines not being co-incident. This is one
of those issues where you need to be careful about when fusion puts in automagic constraints. Sometimes it helps and
sometimes it doesn't - especially if you don't notice them as seems to be the case here. Also fusion sometimes puts
in constraints it thinks you want but you actually don't and you and you have to delete them.
I have suggested you go through the documentation. There are heaps of tutorials and it is a good way to learn fusion.
Another handy trick with constraints is to use the Sketch.ShowUnderconstrained command in the Text Command box.
Cheers
Andrew
107merc
Thanks everyone for responding. That was the problem. No, that was MY problem.
