Enter point location using XYZ
Message 1 of 9
Is there any way to enter points using XYZ coordinates instead of creating a plane and dimensioning on the new plane for each point?
Todd
Replies (8)
Message 2 of 9
innovatenate
Autodesk Support
Autodesk Support
The attached script should allow you to import points from a CSV file. It's a modified version of the ImportSplineCSV script from the below forum thread.
http://forums.autodesk.com/t5/design-and-documentation/importing-point-cloud-in-single-plane-from-a-...
Please let me know if you have any questions about how to use it.
Thanks!
Nathan Chandler
Principal Specialist
Message 3 of 9
kjellhar
Maybe @Anonymous got his answer, but I'm reading his question a bit different.
So, is there a way to enter a point coordinate through a dialog or similar. I mean, it's not unheard of that various cad tools have a way to enter these values on a command line if you want them positioned just right. I know this can be done using the parametric tools, but some times it is a bit annoying to add all that clutter to a drawing.
The mentioned script sure is useful, but for a different task.
Cheers,
Kjell
Micro electronics expert, CAD/CAM enthusiast
Message 4 of 9
innovatenate
Autodesk Support
Autodesk Support
An Idea for precise input for sketch geometry has been accepted in the IdeaStation and backlogged for a future release. At this time, there is no precise input dialog available during the creation of the first point for various sketch entities (including points).
To work around this:
  • You can create a point at 0,0,0 and then use the move command to move the sketch point into place.
  • You can also dimension a point to position in-plane as mentioned in the initial comments.
  • If you know where the points are going to be, you can create a CSV file containing XYZ coordinate and then import them using the script.
I hope that helps! Let me know if you have any questions!
Cheers,
Nathan Chandler
Message 5 of 9
Cheers,
Kjell
Kjell,
  It's like you read my mind.  The script does look useful, but I was asking about simple XYZ dialog inputs.
Edit-
@innovatenate,
 We posted at the same time.  I will try your solutions, and I placed my vote for precise input.
Todd
Message 6 of 9
kjellhar
It would be a nice feature to add. The workarounds thtat you suggest sure solves the problem, but they are all a bit awkward to use.
Kjell
Message 7 of 9
I'd just say: Back to the labs!
I've learned that parametric modelling is based on constraints. But there are some constraints that are simply contraproductive.
@innovatenate wrote:
... At this time, there is no precise input dialog available during the creation of the first point for various sketch entities (including points).
Message 8 of 9
innovatenate
Autodesk Support
Autodesk Support
There's this other discussion that may be helpful. I wanted to reference it (just in case). There's another script you may find useful that will allow you to insert a point by XYZ coordinates.
https://forums.autodesk.com/t5/design-validate-document/enter-a-construction-point-using-xyz-coordin...
Voting in the ideastation is the best way to let the product management team know about the features that you want. Thanks for participating!
Nathan Chandler
Message 9 of 9
Nathan,
thanks for the pointer. While attempting the set_point_@0,0,0_and_then_move_it method, I was confronted with another constraint.
