Announcements
Engrave / indent / imprint text
I can't able to extrude the text in the modelling software.  I have attached the file.  In that there is a plane with text written in modelling software and other text is done with decal are there.  So, please don't confuse
I want to engrave the text that is done in modelling.  Please help
Replies (9)
HughesTooling
Not sure what you're after but if I use extrude and pick the text it extrudes.
Mark
Mark Hughes
Owner, Hughes Tooling
I am really thankful.
I have tried with all the options but it has shown the error.  But today it's done.  I have executed the task for 02hrs 30 minutes.
Can I know that because of the processor will there be any problem to solve?
Thanks & Regards
Naga Ranjith Kumar A
Please find the attached file.
I have got the problem again.  See the error beside
I have seen the problems with the text type.
Please try with square bold text and try to do the same extrusion. Will encounter the same problem, that I have got.
HughesTooling
It's hard to tell from that angle, what font are you using and what is the text. Sometimes you'll find one letter in a font doesn't extrude.
Something you could try, edit the sketch with the text, right click on the text and explode and see what the curves are like and see if they will extrude.
Mark
Mark Hughes
I have attached the updated files
I am using Square bold.  I have to engrave with this text only as per my professor
HughesTooling
I don't have that font so I can't test. Did you try the Explode Text command?
Mark
Mark Hughes
There is no option for that to explode.   I have been trying from the past two days.
Could you please find the solution for that font?
HughesTooling
Right click the sketch with the text, select Edit. In the sketch right click on the text and select Explode Text.
I can't help you with the font you're using because I don't have it on my computers.
Mark
Mark Hughes
