Enabling Contact Sets locks motion study
Hi
I have been working with Fusion for a while now and decided to try the joints and motion capabilities.
The model I'm working on is an engine, as can be seen in the image below, the crankshaft and pistons are working fine but I'm not able to get the camshaft to function correctly.
There's only one valve right now which I'm trying to get to work properly before moving to the next ones.
What is happening is that when I do not add any contact sets the valve collides with the camshaft during motion study (and thus the valve stays motionless):
The movement of the camshaft is limited to rotation, the movement of the valve is limited to sliding across its central axis, which means that it can only go up or down.
When creating a contact set between this camshaft and the valve, Fusion seems inable to process the movement needed to avoid a collision of the valve and the camshaft. The only movement that should happen is the valve moving down, which is not happening.
I can add a motion link between the two though which, I think, means the parts are not too limited in their movement (while the camshaft rotates the valve goes down steadily by the defined mm per rotational degree of the camshaft).
How can I solve this issue? Thank you kindly!
Just fyi, I checked these threads:
But somehow these steps do not work here.
