Empty STEP files
Empty STEP files
Hannahmarti
Observer Observer
Empty STEP files
Hannahmarti
Observer
Observer
Hi there,
I'm having trouble with exporting a Fusion 360 file to a STEP-file. I tried different ways to export but nothing worked.
It's one solid single body so it shouldn't have any problems but when I go to file > export > choose STEP and save it on my desktop, it creates a file that is empty and still is 1,2 MB -> I tried to attach it here, but that failed as well.
Here the public link to the F360-file: https://a360.co/2NodFnr
I would be happy if you could help me out!
Thanks in advance.
tallisb
Hello-
I was able to recreate your issue of the step file coming in empty.  That is odd.
I did find a work-around, though...
1.  Do a File-->Export of your part as an IGES file.
2.  Then open the IGES file into Fusion 360.
3.  Finally, do an Export of the IGES part as a STEP file.
I was able to open the step file after doing the above steps.
Hope this helps.
Brad
Brad Tallis
Fusion 360 Technical Specialist
Hannahmarti
Observer
Observer
Thanks! That works!
But do you have an idea why I can't do it directly?
helloNBJSC
Observer
Observer
I was having this same issue, but was able to solve it. For whatever reason, you can not be "editing" a sketch when you export as a .STEP file. So, enure that you click "Finish Sketch", before exporting and your .STEP file should no longer be blank / empty.
