Embossing on inside of ring
carmine_a_dichiara
carmine_a_dichiara
So I'm struggling with embossing on inside of ring. I'm thinking the issue is that I can't get a dedicated face for the word to project upon. I also realize that that might leave the mistake in the construction of the ring, not in the embossing.
Project attached - would love any advice. Yes there are hacks in the design, especially in the arms ... I'm very proud of what I've learned about Fusion but I am still a novice.
laughingcreek
you just need to do the emboss before you split the ring. roll history back then do the emboss-
davebYYPCU
Presume it's a Deboss, no size mentioned, but works first go, at 0.5mm.
Done before the Split Body as a normal workflow.
Might help...
carmine_a_dichiara
Ah, thank you both ... so I realize there were a couple of things happening here, and your advice helped me realize what was going wrong.
1. Yeah, I suspected the split body was interfering, so I was doing the deboss early in the process.
2. The first problem, I believe, was that the projection of the ring on the inscription was being counted as part of the inscription. The way I could tell this was that if I projected on another surface, like the face of the gem, the outline of the ring was being embossed/debossed as well I believe. Why it's not interfering above for @laughingcreek I can't explain, but I changed the band projection to a construction line and it stopped showing up in the emboss/deboss.
2. I believe the big problem was the chosen font, so I'm going to leave this for someone else struggling with embossing/debossing. If you're trying to use a non-system font and you get a failure like this:
It may be the font you chose.
Thanks to you both, I'll give the solution to @laughingcreek just because the use of Arial cued me to the font issue.
Carmine
