Embossing on a compound curve.
Jaeger1787
Message 1 of 22
Jaeger1787
Gentlemen
I have used the embossing tool on this carriage roof to add the rain strips outlined in blue on the image.  This has worked successfully on the simple curved centre of the roof, but I can not create an embossed entity on the curved ends.
The outline was created on an offset plane.  When I try to emboss, I can select the profile, but not a surface below.
I have tried using Extrude and Project to surface commands, with no result in either.  Any suggestions gratefully explored.
Reading the posts, I see that development work was in progress for an enhanced emboss command.  Is this yet availalable?  I am using Fusion 360 2.0.15050 running on Windows 10.
Accepted solutions (3)
Replies (21)
Message 2 of 22
g-andresen
Embossing is (currently) only possible on a single surface, which must not multiple curved.
günther
Message 3 of 22
Jaeger1787
Thanks for confirming what I suspected.  Is there any work-around to extend these strips onto the curved ends?
Message 4 of 22
Warmingup1953
Not my trick but a Surrogate Emboss may well work here?
https://www.youtube.com/watch?v=2uNZGPJuIpw&t=89s&ab_channel=Fusion360School
Message 5 of 22
g-andresen
Please share the file and show what you want to emboss and on which surfaces.
günther
Message 6 of 22
Jaeger1787
GÜnter.
Wilco. Probably tomorrow.
Message 7 of 22
billbedford
It is a lot easier to project the two outlines onto the three surfaces of your roof and the loft a profile of your rain strips along both projected lines.
And it's still easier to model a quarter of the roof and then use two mirrors to get the whole one.
Message 8 of 22
jeff_strater
embossing to doubly curved surfaces is coming...  We've been working on it.  I have lost track of exactly when it will be released, and I know that does not help you today, but we are excited to get this feature out in the world.
Jeff Strater
Engineering Director
Message 9 of 22
Jaeger1787
Many thanks for the suggestions and information, guys. I look forward to an enhanced emboss tool in the future.  Meanwhile I think I may have had a workaround suggested that will do the trick.  Essentially, it means creating a sweep/loft of the missing parts of the rain strip.  Bill Bedford's suggestion of mirroring also seems a useful shortcut, so thanks again.
Keith
Message 10 of 22
Jaeger1787
Gentlemen.
I have tried Bill Bedford's suggestion of extruding, or projecting the outline of the rain strips to the end curved surfaces, but to no avail.
I attach the file for you to have a play with.
Message 11 of 22
jhackney1972
How about using a different method.  This is done using Surfaces.  Model attached.
John Hackney, Retired
Message 12 of 22
jhackney1972
I would love to have some feedback on the results I posted, does it suit your needs?  If if does and you need further explanation, let me know.  If not tell me why.
Message 13 of 22
Jaeger1787
I was looking at your video as your message popped up.  Still trying to
work out exactly how you achieved it.  Now scrolling through YouTube
videos for further guidance.  Don't be surprised if I ask for more help
though.  Thanks.
Keith
Message 14 of 22
jhackney1972
All I was waiting for was if the model suited your needs and then I would do the video. I assume it does, by your comments, so here it is.  Do not forget to select Accept Solution on my method if it truly suits your needs, you can have more than one solution per post.  You have the model so I will not attach it again.
Message 15 of 22
Jaeger1787
Thank you Sir.  That is exactly what I was looking for.  I have clicked Accept Solution.   I did follow a similar suggestion earlier but for some reason, I could not remove the section of the body below the roof.    Many thanks.
Keith
Message 16 of 22
adamgmalone
Observer
Observer
Hi Jeff,
New to Fusion and straight away have found this limit with "emboss" on compound curves (Think the end of a trumpet flair). Is the any further word or timeframe for the introduction of a compound curve emboss feature?
Cheers
Adam
Message 17 of 22
Warmingup1953
Message 18 of 22
billbedford
This is my file of a roof with rain strips.
Message 19 of 22
jhackney1972
You did not give much information on what you want to accomplish, thickness, add or subtract so I just guessed.  I did not use Emboss but surfaces.  The thickness is an addition of 2 mm but can be edited.  If you want to subtract material just revers the Combine.  Model attached.
Message 20 of 22
Jaeger1787
Last year, Mr. Hackney very kindly sent me a video describing how to produce the required result (rain strips on a compound curved surface). After a considerable hiatus, I am now trying to complete my model.  I have followed the advice as closely as I can but I am failing every time, with different error messages coming up.  The latest message is: 'Coincident tools would create illegal or non-manufacturable bodies.  Try with separate tools.'  I managed to remove the rain strip extrusion on top of the roof, but get the error message when attempting to split and remove the lower body extrusion.
I attach the latest version of the file.
