Emboss broken
Emboss broken
eric_frederich
Message 1 of 13
Emboss broken
eric_frederich
https://youtu.be/o5rcAv7xVUo?si=7uolaCAkw72_-1qG&t=556
Hi, trying to follow this simple guide.  When it came time to emboss I was getting an error: "Error: Cannot create emboss feature. Adjust sketch profiles, faces, emboss depth, effect, or alignment options."
I went back to the sketch and made it a simple rectangle (i.e. did not put the 2 point circle on top).
When I did this the resulting emboss was all curvy (see screenshot).
Currently the sketch is dimensioned 2mm from the edge.  The further it gets from the edge (i.e. closer to the center) the less wacky it gets.
What am I doing wrong?
I attached a screenshot and the f3d file.
Replies (12)
Message 2 of 13
jhackney1972
Remove the Tangent Chain box check and then select all the the Faces you want to Emboss manually.  Model Attached.
If this answers your question, please select the "Accept Solution" icon on my post. If you have further questions, please ask.
John Hackney, Retired
Message 3 of 13
eric_frederich
Thanks for the suggestion.  I tried that prior.  When I unselect Tangent Chain with the two Sketch Profiles selected I am only able to select a single face, it won't let me select more than that.
I need to select 3.
Message 4 of 13
jhackney1972
You have not learned that holding the Ctrl (Command) key allows you to select multiple surfaces to Emboss to. Try it, if you cannot get it to work I will create a video.
Message 5 of 13
eric_frederich
Okay, thanks, that worked.
I guess this is the first time I've had to select multiple things for multiple attributes.
It seems the 2nd selection set needs to use Ctrl.
If you select profiles first, then you have to use Ctrl on the faces.
If you select faces first, then you have to use Ctrl on the profiles.
Thanks for the help.
I'll mention this in a command on the YouTube video in case anyone else is trying to follow along.
Message 6 of 13
LunarHamster
YES!!! THANK YOU!! I just found this and it helped me! THANK YOU!! THANK YOU!! THANK YOU!! THANK YOU!! THANK YOU!!
This trophy is for you!
Autodesk should change the answer here. jhackney1972 gave the correct answer!!
Message 7 of 13
stevegoodmansen
Community Visitor
Community Visitor
I can't get this to work, even after reading the solution.  It seems something has changed in Fusion since that Youtube tutorial was made.
Message 8 of 13
jhackney1972
Please attach your model and a screen capture of your problem.  As it is now, no one knows what your Fusion issue is.
Message 9 of 13
TheCADWhisperer
Message 10 of 13
nicola.graham
Can anyone help with a similar issue? I have created an emboss on a parametric design and it works weel for 4 out of the 5 configurations. I cannot work out what is wrong with the 1 configuration that is not working. File attached.
FYI - configuration 4 is the one that will not work.
Message 11 of 13
gautham_kattethota
@nicola.graham
On an internal build i do see the emboss for Configuration 4 appearing fine.  Are you saying the text is not appearing for this Configuration on your Fusion build?  Its a pretty simple setup in the Configuration table, so I am guessing it should work.  Can you attach an image of config 4 showing where the problem is.
Gautham
Gautham Kattethota
Software Development
Message 12 of 13
nicola.graham
@gautham_kattethota thanks for replying. The issue seems to have resolved itself! I am now having an issue with configuration 5 and the fillet as below! Any advice?
Message 13 of 13
drew22losee
fusion has had some dogwater updates. breaking previously working tools.
vibe coded program
