Emboss a stone-like pattern over a big face
ricardo.peironcely
ricardo.peironcely
I'm trying to use fusion360 to model a stone bridge for a railway model layout.
I have a simple bridge structure and I want to emboss a stone like pattern on it. For it I've created one sketch with the tessellation, adding manually some errors, but when I try to repeat this with create > rectangular pattern, fusion360 hangs.
Seems that the sketch is too complicated,
Has somebody any idea about a workflow to do this?
https://knowledge.autodesk.com/community/screencast/c0391286-51c4-42c2-bc90-87b7bb938c83
g-andresen
Patterns should always be created from features, not sketches. To do this, you could create 2 sketch features of the stone profile, extrude them and then generate the patterns from them.
Please upload a sample f3d file for demonstration
günther
g-andresen
In the screencast I show one way to reduce the pattern problem of sketches.
I created an elementary sketch for 3 extrusion profiles, then extruded them on an auxiliary body and created the stone pattern from these features with two rectangular patterns.
This pattern is then projected into a sketch and embossed onto the bridge wall.
günther
