Elaborate on Offset Functionality
Can someone elaborate on the functionality of the offset function in Fusion 360?
I feel like it is very inconsistent. For example, sometimes I can extrude sketches that were based on offsetting sketches and other times it gives me errors. Another example is sometimes I can offset a shape (closed spline that is very circular) and other times it gives me an error.
TrippyLighting
It does what the name of the function indicate, but it has limitations and probably a bug or two involved.
If you present your "problem cases" maybe through a screencast, maybe we can address these better.
wilkhui
Hi Sarah - as @TrippyLighting mentioned, attaching your problem cases as .f3d files is the best way for us to understand what you're facing, along with screenshots and videos where possible 🙂
Indy
Inderjeet Singh Wilkhu
Product Owner - ASM
Autodesk, Inc.
@wilkhui@TrippyLighting- it happens so inconsistently that I don't know when I can get it to work and get a screen cast of it. I've been trying to figure it out for that past few months and have had no success.
wilkhui
Hi Sarah - if you get a chance to detail some specific examples that would be great, at the moment I don't have any way of knowing what you're seeing so the more information you can provide the better Smiley Happy
Example of what to do when you get a result you didn't expect:
1. Try to remember what you just did
2. Hit 'undo'
3. Save a version of the file (before things went wrong)
4. Try to get the unexpected result again
5. If you find a repeatable method, recordings are invaluable to show to others what's happening (have a look at Screencast)
6. Start a new post explaining what's going wrong, include the method, recording and the file/s from step 3
Hope that you get to enjoy the holidays, Merry Christmas and Happy New Year!
Indy
Product Owner - ASM
Autodesk, Inc.
The workflow is the same every time.
I offset a sketch and try and loft it to another offset sketch. This workflow works about 50% of the time
