Efficient way of creating this part
Hi all,
What would be your take on creating the part seen on the screenshot below in the most efficient way?
I know that it is possible to pattern the object using a path, but then I must specify the amount of objects that I want along the path, which isn't handy + F360 will start "not responding" after inserting large numbers, for example, if I input 60 objects along the path, it crashes (the PC is powerful, so specs is not the issue of not handling).
P.S. Is there a command of automatically filling in the pattern with objects? It can be calculated by measuring the length of the path, for example 150mm, and then measuring the length of the object, for example 1 mm, which would mean that we need 150 objects to fill in the path, but is there a way of automating this?
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
