Editing STEP files
I have a STEP file which needs a little modification before I can mill it. No matter what I try, I just cannot get it done. I can quite easily remove "stuff" with PressPull in Modelling environment. And sometimes even add, when the surfaces are not curved.
But now I need to extend one complex surface out 4mm, but I cannot find the proper tools to do it. Target is in the attachment, what I want to do is to fill up the space smoothly between the brown extruded bit and rest of the body. I created 3-point construction planes where I needed the surface to be, drew the sketch lines, but in no way I could fill up the contours afterwards...
How should I approach this?
File itself is available at http://a360.co/1HGYlb6
