Dear All,
Have a question about converting an imported part to sheetmetal part.
When I get a Step format part i need to modify or just create a drawing or dxf from it incl flat pattern, i have problem with the bending radius.
I have pre configured sheet metal rules, but the original step file was drawn with a different bend radius. And this is the case most of the time... (I have to adapt the sheet metal parts to the particular manufacturers specs many times.)
So how could I change all the parameters like bend radius and k factor etc after i convert an imported (step) part which was drawn in a different software as a sheetmetal part with a particular (different) sheet metal rule?
Tamas
