Editing copied component
montyonthebonty
montyonthebonty
Good morning
I'm designing a box to be laser-cut. I've made a component for the back, but I want a cutout on the front only.
Currently, if I copy the component, any changes I make to one apply to the other. I don't want to lose this (in case I have to resize it), but I want to be able to add the cutout to just one instance of the component.
Is this possible on a personal licence, or do I have to create a new component from scratch if I want it to be different?
Chris
davebYYPCU
Yes, use Copy / Paste New.
Might help....
laughingcreek
past/new is a good way.  it makes the 2 components completely independent of each other.  if you want to keep some dependency between the two, have a look at the attached model.  and a video to go with it-
montyonthebonty
Thanks - yes, I want to keep a little dependency.
For example one side will have a cutout for a USB port, but I still want them both to resize if I change the dimensions of the model.
Thanks for your help.
Chris
