Edit In Place Broken?
shawn3WMTV
Message 1 of 9
shawn3WMTV
With this latest january release, I can not longer edit in place an take reference for another part in an assembly. As soon as I select edit in place for a component, all other components disappear.
Why would this be? The entire point of edit inm place is to take references from other components.
Replies (8)
Message 2 of 9
shawn3WMTV
I guess I have not seen this new conext  menu at the top of the window. You have to select which objects to reference and set their visibility.
But I can not set them to be shaded with visible edges. Is there a reason for this?
Message 3 of 9
jhackney1972
Attach an example of your needs and work.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it. If needed, ZIP a F3Z file.
John Hackney, Retired
Message 4 of 9
johnsonshiue
Hi! Go to Preferences -> General -> Design -> Assembly -> uncheck "Active Component Visibility."
Many thanks!
Software Test Engineer
Message 5 of 9
rosie_lucas1
Hello @shawn3WMTV,
Just checking in— did you see the request from @jhackney1972 for additional information or did the response shared by @johnsonshiue help clarify your question?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Rosie | Community Manager
Message 6 of 9
theoebing
Observer
Observer
I followed your proposed solution, now my components are highlighted in red and no visual available......
Message 7 of 9
jhackney1972
Could you attach your F3Z file of the assembly giving you issues.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it. If needed, ZIP a F3Z file.
Message 8 of 9
theoebing
Observer
Observer
Here you go!
Message 9 of 9
jhackney1972
You attached file, when opened, does not contain any data.  Please export and attach file that is causing your issue.
