Edit Form - Undo change without losing dialog?
Hi there,
When using Edit Form to adjust a tspline, I often make a change, don't like it, and want to undo it.
I have three options it seems.
1) Hit escape and lose the dialog, and have to open it up again. Super frustrating for workflow.
2) Hit command-Z and lose the dialog and have to open it up again.
3) Go into the dialog and type in whatever the original number was, such as "1" or "0","0". Also super frustrating for workflow.
Is there any way to cancel the input without losing your Edit Form dialog?
herzinj
Hi Luke,
Thanks for the post.  Unfortunately I do not know a better way to do this, but hopefully someone else has a better idea.  I think the best way to do this would be to have a button on the dialog like "restore to default" or "restore to previous form."  I also think that the control+z command should work!  This would probably be a good suggestion to add to the IdeaStation if no one is able to provide you with a good solution.  Sorry for the inconvenience!
James
https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png
Please god no more buttons. Fusion is so UI click happy already I think my head would explode if we had more buttons.
It's amazing what some CAD programs can do with a right click.
