Edit Form doesn't update model
rbuckDF7GX
rbuckDF7GX
I (thought) I was a reasonably fluent user of Forms, but I'm out to sea here...
I have created 3 forms (which do overlap) using loft along a spine in Form space. In this model I have only used forms (so far) - no surface or patch. I have been editing the forms (Edit Form) and somewhere along the way my t-spline bodies went away and I was left with surfaces. I didn't notice as I was jumping into edit form regularly via edit feature and updating successfully. Then F360 crashed. The recovery file seemed to have merged two of the bodies together; it seemed I had 3 surface bodies and one t-spline body but only the surface bodies showed in the model tree. I ended up hiding the "nonexistent" Form leaving me with 3 surface bodies. Now however, when I use Edit Form, the edited form shows, but when I Finish Form I'm left with the original surface body. This is shown in the video.
So, what did I do to end up with my forms turning into surfaces? and why do I seem to be able to edit the form but end up with neither a t-spline body or an updated surface?
Really could use some advice here as I stand to lose quite a bit of work if I need to start over..
Thanks, Ron
MacOS 15.3 f360 2.0.8412
Accepted solutions (3)
TrippyLighting
Can you share your model? (export as .f3d and attach to next post)
jeff_strater
@rbuckDF7GX - "and somewhere along the way my t-spline bodies went away and I was left with surfaces" - this is the way that Form features work in a parametric design - when you exit from Form mode, the T-Spline bodies are converted into BRep bodies - if the T-Spline is open, that will be a surface body, if closed, it will be a solid.  I see in your timeline you have 3 Form features - each one most likely has a single T-Spline body with it.  If you edit the first, you will only see the T-Spline for that feature.  As @TrippyLighting says, though, unless you can share the model here, we can only really guess...  Thanks!
Jeff Strater
Engineering Director
rbuckDF7GX
Jeff, Peter, thanks for looking. Sorry I've been away for a few days.
So Jeff, I realized after posting that the open form would give me a surface feature (just forgot :-/). Thanks for reminding me.
I found (via desperate random actions) that copying the Form that wouldn't edit/update (while in form space), leaving form space, then re-entering form space and deleting the copy cleared what ever issue was blocking me from getting the update. I hope that makes sense. I'm guessing that the F360 crash had corrupted my model. No amount of re-computes, saves, exiting F360 helped, but that copy/delete did, and I'm moving forward again.
If you still have some interest in pursuing I'll try to find/post a copy of the corrupted file, but otherwise I'm writing this off as "disaster avoided".
Unless you think I may be running on borrowed time, and this may still come back to bite me?
Ron
