edit by curve on fusion 360
HI , i have a question, i check on fusion the tool "edit by curve"
this tool is very important, and i use it on speedform, i'd like find it on fusion
do you know if this tool will be here on fusion 360?
innovatenate
Autodesk Support
Autodesk Support
Thanks for inquiring about this feature. I'll check in with our product managers and see what I can find out.
If you have access to Speedform, have you considered trying to transfer your t-spline bodies from Speedform to Fusion? I haven't tried this myself, but it seems like you could use the control frame to export an obj or the convert tool or something to move a sculpt body into Fusion.
I'll follow up as soon as I receive an update from the product management team.
Thanks!
Nathan Chandler
Principal Specialist
colin.smith
Hi @Anonymous,
This feature is on our list, we don't have a set release date yet.
Colin
Colin Smith
Sr. Product Manager
SketchBook
Alias Create VR (aka Project Sugarhill)
Automotive & Conceptual Design Group
thanks a lot,
Sure i have done your suggestion, when i knew this step i was very happy, is a good day to comunicate between software, this step works also with maya
but edit curve is much more intuitive and speedy
thanks again, and let me know when you get it inside
PhilProcarioJr
@Anonymous
Please add this to the ideastation, I would definitely vote in favor of it.
Phil Procario Jr.
Owner, Laser & CNC Creations
TrippyLighting
Yes, please add this to the idea station!
