Dynamic text replacement
I've got a component with a text field.
I need to 3d print this component multiple times with different text.
Is there a way to automate this?
jhackney1972
Text values, entered using the Sketch Text function, cannot be parametric.  I then think the best you can hope for is to manually edit the Component sketch, edit the text sketch, change the value and export the 3D print three times.
John Hackney, Retired
jeff_strater
not with the standard features of Fusion, no.  There might be an add-in that exists that could help automate this, but it would basically do what you would have to do manually:  edit the text, print, repeat.
Jeff Strater
Engineering Director
HughesTooling
There's a nice add in here for parametric text.
https://apps.autodesk.com/FUSION/en/Detail/Index?id=2114937992453312456&appLang=en&os=Mac
Mark
Mark Hughes
Owner, Hughes Tooling
Thank you - that works.
