DXF Files slow to respond
AmishSolanki
AmishSolanki
I get the occasional DXF files from customers and I find they are EXTREMELY slow to work with. Complex ones end up hanging fusion for several minutes, if not crashing it completely. Any idea?
SS CADCAM - www.sscadcam.com
@sscadcam
HughesTooling
Are you using InsertDXF from the insert menu? If you use layers in the DXF you have the option to save each layer as a sketch you can then hide sketches to speed things up a bit.
Mark
Mark Hughes
Owner, Hughes Tooling
