Duplicate and customize parametric component
VGBenjamin
VGBenjamin
Do I have a way to create a model from a sketch base on parameters for the dimensions and then duplicate and customize the dimensions of the second instance.
I am doing piece of furniture (or at least trying to 😉 ) and I creating the doors for example and it is always the same but with different dimensions.
Benjamin
shahriarsifat1802164
Can you please attach your files?
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
g-andresen
1. Create component 1
2. create user parameters W/H  1,2,3 ... for each door
3. create sketch > door 1 > W1 / H1
4. copy > paste new C 2
5. change sketch (C2) W2 / H2
günther
VGBenjamin
Yes but that is exacly the kind of stuffs that I would like to avoid: to re-edit all the sketchs. They are no possibilities to link a set of parameters  to a component for example?
g-andresen
take a look at this thread
günther
VGBenjamin
Great I didn't saw this thread. Thanks a lot.
It isn't the perfect solution but it is a good start and apparently they are working on a solution for this..
