Duplicate a function - copy extrusion
xmen06
Message 1 of 13
xmen06
Hi all,
I am trying to copy an extrusion from the begin at the en of my project.
Is this possible i don't find this in the menu ?
[ The subject line of this post has been edited for clarity by moderator ]
Replies (12)
Message 2 of 13
Bunga777
 I am sure that features such as extrude cannot be copied.
Array copying is possible.
You can copy the body if you need the same one.
You can copy and paste the body when you get the shape of the body you need by going back to the desired position in the history.
Message 3 of 13
TheCADWhisperer
Are there any unresolved issues highlighted in your Timeline?
Message 4 of 13
xmen06
ok thanks for the reply .
here my files .
Message 5 of 13
g-andresen
There is no need to copy anything.
Take a look at the screencast.
You can also drag the active feature to the end of the timeline and select the desired profiles via Edit.
günther
Message 6 of 13
xmen06
thanks but i don't understand your screencast.
I don't want to remove the part in you screencast i want it to stay and add a hole extrusion  from the begining .
Message 7 of 13
g-andresen
Then please complete your question with a screenshot incl. explanatory hand sketch.
I consulted my crystal ball.
She thinks it's something like this.
günther
Message 8 of 13
xmen06
Ok i have sent picture in the first post.
It's a file i want to modified.
I have extrude the arc to be under .
Now before at the first pic timeline, two holes was generated by extrusion .
I have manged to make the first hole but for the second hole i haven't managed to see the circle sketch to extrude it 😕
Message 9 of 13
g-andresen
Is it too difficult to mark the hole?
Activate the sketch
günther
Message 10 of 13
xmen06
Thanks i have manages to make the hole.
How did you get the menu at 0:10 ?
Message 11 of 13
laughingcreek
long left mouse click pops up a list of everything under the cursor.
Message 12 of 13
xmen06
thanks 🙂
Message 13 of 13
g-andresen
Please watch this screencast
günther
