Ducting for RC Fan Jet
Hi All,
I'm trying to create the duct work that goes from the fuselage intakes to the fan. My plan was to create a solid body of the duct and then use this to cut the channels from the main body.
The two intakes need to merge into one tube that will interface with the front of the fan. In other words a Y duct.
The intakes should follow the outer edge of the body so that the wall thickness remains constant up to a point where it'll need to curve inwards to join with the other side before reaching the fan.
Is a loft with a guide rail(s) the right way to achieve this? As the fan and intakes are at different heights, I'm a bit confused about what plane(s) I would need to sketch on for the guide rail.
Or perhaps there is a better way?
Any tips on how to tackle this would be much appreciated.
Thanks!
