Dropdowns moved
Dropdowns moved
Dropdowns moved
Hi All,
I haven't used Fusion for a little while. I just started it up to do a design and some of the drop down menus have moved. I run dual screens ( monitor 1 is a HD monitor that I use for fusion 360 monitor 2 is a flat screen tv that I use to view Youtube tutorials when I get stuck ). When I use SKETCH , CREATE, MODIFY or CONSTRUCT the drop down appears on the TV not on the monitor that I am running Fusion. I don't seem to be able to drag the menus back to their proper positions.
Any help would be appreciated
Neil
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
Couple quick things we can try here - does going to the File menu, then View, then Resetting to Default Layout seem to do the trick? If not, can you try to right-click a blank space inbetween the Create and Modify menu and reset any customizations that you may have done.
If that does not work, can you post a screenshot of what you are seeing.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Hi James,
Thanks for the reply. I tried all of these yesterday but they had no affect. What I did find was that if I dragged Fusion from my HD monitor onto the TV screen the dropdowns appeared in the right place, so I put up with the poor quality of picture in favour of ease of use.
I fired up the computer this morning and Fusion had taken itself back to the HD monitor and everything was working fine, so I don't know what the problem was but it appears to have fixed itself.
Thanks again
Neil
